Error -1950679020 With LabVIEW Shared Variables
Updated Feb 1, 2023
  • cRIO-9053
On my host PC, I am reading an I/O Variable that is network published from a cRIO but I am getting error -1950679020
Unable to access the shared variable. This error can occur if you attempt to read from a write-only variable or write to a read-only variable, or if you do not have permission to access the variable.
What I can do to fix this error?
This error can be caused if you are working with DIO modules and the I/O direction is not correctly defined to match the operation you are doing with the shared variable (read or write). You can check this by going to the Module Properties:
After setting the correct direction and clicking Ok, remember to do a deploy on the target.
