This message is caused due to LabWindows™/CVI having a default charset that does not have the invalid characters defined. Change the default charset to a different one that includes the invalid characters from your code. For example, the western charset includes characters from languages such as German and French that are not included in other charsets.
To change the default charset follow the next steps:
For LabWindows™/CVI 2019 version or earlier
1. Go to Options>>Font.
2. In the Environment Font Preferences pop-up window check the Source Window Font box and click Edit
3. Change the default charset.
For LabWindows™/CVI 2020
1. Go to Options>>Environment.
2. In the Environment pop-up window locate the Encoding section.
3. In the Character set for interpreting ANSI settings option, change the default charset.
