Usage of *.wt Files in SystemLink Server
Updated Feb 2, 2023
  • SystemLink Server
I noticed several *.wt files with different sizes are present in my computer after installing SystemLink Server. What are these *.wt files and how is SystemLink using them?
The *.wt files are collections in a Mongo database (MongoDB), which are similar to tables in relational databases. These files are located in the C:\ProgramData\National Instruments\Skyline\NoSqlDatabase\db folder.
The MongoDB service used in SystemLink Server stores and manages these files in the back-end. The files contain a variety of information used by the server for its operation, therefore the *.wt files shouldn't be manipulated manually as it can lead to malfunctions within the server.
Some collections in the SystemLink MongoDB can have a large size, for example the files used by the SystemLink Package Repository can increase as more packages and feeds are added to the server.
