Error -201139 in NI-DCPower
Updated Dec 22, 2023
  • PXIe-4135
  • PXIe-4137
  • Power Supply
  • PXI Programmable Power Supply
  • NI-DCPower
I am seeing the following error in NI Measurement & Automation Explorer (MAX) when using the PXIe-4135 or PXIe-4137:
Status Code: -201139
Hardware revision is newer that the latest revision supported by the currently installed driver.
Please upgrade your driver to the version supplied with the device. Driver updates can also be downloaded from ni.com.
Take the following steps to resolve this issue:
  1. Refer to the NI Hardware and Software Operating System Compatibility page.
  2. Make sure the latest NI-DCPower driver is installed, or a version that is compatible with your hardware revision and software.
  3. Restart the controller or chassis.
