How to Adjust Tab Control’s Size at LabVIEW Front Panel
Updated Aug 14, 2024
This example shows how to adjust the size of Tab Control at the LabVIEW's front panel.
You can adjust the size of tab control frame by using either of three methods as shown below.
First method by using Properties setting:
  1. Right click at Tab Control.
  2. Click Properties.
  3. Go to Appearance > edit Height and Width in Size part.
Another way to adjust the Tab Control frame's size is by:
  1. Right click the Tab Control.
  2. Click Fit Control to Pane and tab size will be fit to your screen size.
Or you also can manually drag tab frame to adjust the size.
