Error 0xBFFA4214 When Creating NI Switch Executive Virtual Device
Updated Nov 23, 2022
  • Switch Executive
  • I am trying to create a Switch Executive Virtual Device in NI Measurement & Automation Explorer (MAX), but I keep receiving error 0xBFFA4214. How can I resolve this?
  • Whenever I try to create a Switch Executive Virtual Device, I see a Timeout expired before operation completed error. What's causing this?
  • How can I resolve the below error?
An error has occurred while attempting to access device <type>
Primary Error: (Hex 0xBFFA4214) Unknown status code.
Elaboration: I/O error. Timeout expired before operation completed.
This error is most commonly caused by one of the following factors. Work through the steps to resolve this error:
  1. Insufficient timeout.
    • If a custom driver has been created for the device, or if the driver source code is available, increase the default VISA timeout value.
  2. Incorrect DLL path.
    • Verify that the path to the IVI driver is correct by following the steps below:
      1. In NI MAX, expand IVI Drivers >> Driver Sessions.
      2. Select the Driver Session that corresponds to your Switch Executive Virtual Device.
      3. Navigate to the directory listed under Module Path (32-bit) and Module Path (64-bit) if applicable.
      4. Check that the DLL is present and.
  3. Multiple versions of the same DLL.
    • Ensure that only one version of the driver DLL exists on the host PC.
