Follow the steps below to configure custom properties and view them from SystemLink Server. Before proceeding, ensure that the Test Monitor plugin has been integrated into TestStand. Refer to
Integrating Test Monitor with TestStand for instructions.
1. Create and save a TestStand Sequence.
2. From the
Insertion Palette, drag the
Add Keyword and
Add Property steps into the sequence.
3. In the
Step Settings for
Add Keyword, define a custom keyword.
- For demonstration purposes, this article references a keyword called "TestKey".
4. In the
Step Settings for
Add Property, define a custom property.
- In the Key field, specify the name for the property. In the Value field, specify a value for the property.
- For demonstration purposes, this article references a property called "TestProperty" with a value of "test".
5. Run the TestStand Sequence.
6. In a browser, navigate to the SystemLink Server URL and login.
- To find your SystemLink Server URL, open NI Web Server Configuration from the Windows Start Menu.
- In the Applications tab, copy the NI SystemLink URL.
7. In SystemLink Server, navigate to
Test Insights >> Results to view the TestStand Sequence results.
8. The top result in the table will correspond to the latest TestStand Sequence that ran. Double-click the top result.
9. In the
Test Result Details section, the custom keyword will appear under
Keywords.
10. Select the pencil icon from the top-right corner of
Test Result Details.
11. In the
Edit Display Properties window, click the addition symbol.
12. Enter the name of the custom property that was configured in TestStand. Click
Update.
13. The custom property will now be visible from the
