This error occurs due to insufficient privileges. Check the points below to resolve this error:
- Ensure that full control has been enabled for the LXI Discovery executable.
- Navigate to C:\Program Files (x86)\National Instruments\Shared\NI-VISA.
- Right-click on niLxiDiscovery.exe and select Properties.
- In the pop-up window, select the Security tab.
- Ensure that Full Control has been allowed for your user account.
- Ensure that you're launching Package Manager as an administrator.
- Search for "NI Package Manager" in the Windows start menu.
- Right-click the application and select Run as administrator.
- Manually stop the LXI Discovery Service and restart the software installation.
- In the Windows start menu, search for "Services" and launch the application.
- Scroll through the services to locate NI LXI Discovery Service.
- Right-click on the service and select Stop.
- Retry the software installation.
Note: Ensure that you restart the service after the installation completes.
- If for any reason you are unable to stop the LXI Discovery Service, change the Startup Type to Manual and restart your system.
- In the Windows start menu, search for Services and launch the application.
- Right-click on the service and select Properties
- Change Startup Type to Manual
- Restart your system and retry the software installation.
