Using the DAQAssistant on LabVIEW 2026 Q1 with DAQmx 2026 Q1 installed fails to complete the DAQAssistant configuration process and gives the following code generation error:
LabVIEW Code Generation failed to execute. This may occur if the code gen engine is not properly installed, or if you are using a LabVIEW version under development.
This behavior has been also observed in LabVIEW 2022Q3, LabVIEW 2023Q1 and LabVIEW 2023Q3.
