Invalid Script File Selected Error in Vision Assistant
Updated Nov 14, 2022
  • Vision Assistant
I have created a script using Vision Assistant 2022 Q3 and when I try to open it in an older version of Vision Assistant, this error happens. Why did this error happen and how can I resolve this issue?
Invalid script file selected.
Vision Assistant is not forward-compatible. Hence, a script created in a newer version of Vision Assistant cannot be opened in an older version. Kindly use the version of Vision Assistant that the script is created from or the newer version to open the script.
