Error -356004 on Ethernet RIO Expansion Chassis
Updated Nov 9, 2022
  • NI-9147
Other
I get error code -356004 when using the Ethernet Expansion Chassis
LabVIEW cannot find the I/O Variable Remote Configuration Web Service on the remote target
How can I solve it?
You need to install the "I/O Variable Remote Configuration Web Service" component to your Real-Time target from MAX, this should fix the issue
