A Kernel Matrix is a special type of matrix. It can be built in LabVIEW by providing the required coefficients of the matrix to
IMAQ Build Kernel VI
The coefficients required can be manually entered into a string constant as shown below and then fed into the IMAQ Build Kernel VI
This method can also be used to create other kinds of standard matrices.
