1. Use
RFmx Waveform Creator to generate 1MHz Tone waveform and send it out
2. Use RFmx SpecAn to receive the signal, and see the result received under the default settings as follows
It can be seen that the measurement result is that two Tones exist, this is because the default mode is I&Q mode
3. Open the settings panel and select I only mode
