For the steps, we will focus on an NR EVM measurement using the RFmx Soft Front Panel within InstrumentStudio™.
First, we will open the RFmx Soft Front Panel by clicking on the InstrumentsStudio button from the instrument window within NI Measurement and Automation Explorer (MAX):
Then click on Personalities and select the desired personality (for this case we will select NR):
By default, the NR layout will include the ACP and ModAcc measurement panels with the RMS EVM per Subcarrier Mean graph and the PUSCH Constellation, but in this article, we will focus on the EVM measurement.
For configuring the settings for the EVM measurement we should pay attention to the waveform that we are expecting. In this case, it is a 2x10MHz Uplink waveform with a center frequency of 3.5 GHz and an output power level of -10 dBm which we created following the instructions in the article
Creating and Generating Signals Using NI RFmx Waveform Creator, and we are generating it as shown below:
Based on the characteristics of the waveform we are measuring (we have connected the RF OUT and RF IN ports of the VST in loopback for this example) we should configure the center frequency to 3.5 GHz, the Bandwidth to 10 MHz, the Reference level to 4.5 dBm, the Subcarrier spacing to 15 kHz, and add an additional subblock with the Component Carrier 0 settings (this is also illustrated on the above Knowledge Base article).
