Error 403002 When Deploying Ballard ARINC 429 Custom Device
Updated Nov 8, 2022
  • Ballard ARINC-429
  • VeriStand
  • VeriStand Custom Devices
I'm using Ballard ARINC 429 Custom Device. When deploying the target, error 403002 was reported. How to solve this issue?
Error 403002 may point to several reasons resulting from the configuration files. You can take these actions for debugging,
  • Check the User Guide to review your configuration files.
  • Test the example configuration files with your hardware, and compare them to review your configuration files.
  • Check label name attributes in the hardware configuration file. The TX channel labels' name attributes must be "label xx" or "label xx_yy", among which xx is the decimal label number, and yy is the decimal SDI number if SDI is enabled.
You can find the descriptions for the Ballard API errors here for your own reference.
