Disabling Anti-aliasing Filter on PXI Oscilloscope
Updated May 10, 2024
  • PXI Oscilloscope
  • Oscilloscope Device
This article explains how you can disable the anti-aliasing filter on PXI Oscilloscope devices.
niScope Configure Chan Characteristics.vi, a function that is a part of NI-SCOPE APIs in LabVIEW, can be used to disable the anti-aliasing filter.
To disable the filter, input '-1' to the max input frequency terminal of the VI. This will allow you to read the full bandwidth of the signal.
