I am using the SystemLink API to query test steps using the SystemLink API with the Test Monitor Web Service. When I call the/v2/query-steps function on a SystemLink 19.6 server, the following payload times out but on the version 2022 Q1 server it runs without issue and returns all data:
"filter": "",
"substitutions": [],
"resultFilter": "(id == \"123456789123456789\")",
"resultSubstitutions": [],
"orderBy": "STEP_TYPE",
"descending": false,
"projection": ["NAME", "STEP_TYPE", "STEP_ID", "PARENT_ID", "RESULT_ID", "STATUS", "TOTAL_TIME_IN_SECONDS", "STARTED_AT", "INPUTS", "OUTPUTS", "DATA_MODEL", "DATA"],
"take": -1,
"continuationToken": "",
"returnCount": false,
"responseFormat": "JSON"
