In order to properly display the XY Graph in the TestStand report, you should use
2D Waveform Graph in LabVIEW. This is because the XY Graph in TestStand is classified as a container type with two 1D array elements. The X-axis and Y-axis values will be saved separately in the TestStand container and thus result in two different graphs. By using 2D Waveform Graph, the result is saved in 2D array in TestStand.
In some consequences, when using 2D Waveform Graph to display XY Graph in the TestStand report, you may get an incorrect result also. You may try to click
Refresh in the TestStand report (as shown below) to refresh the plotted graph so that you can obtain the correct XY graph.
