Cannot Use Ni-Industrial Communications for Ethernet/IP 2022Q3 With Prior to LabVIEW 2022
Updated Jun 16, 2023
  • Ethernet/IP Driver
I would like to use NI-Industrial Communications for EtherNet/IP (IndCom) 2022Q3 with LabVIEW 2021 SP1 or previous version. The installation was successfully completed but I couldn't find IndCom VIs in LabVIEW pallete.
IndCom 2022Q3 supports LabVIEW 2022 or later. Please refer readme for the details.
You can still use IndCom 21.0 or previous version with LabVIEW 2021 SP1. There is no new feature added in IndCom 2022Q3 apart from ADE independence.
