This article demonstrates how to use a regular expression in TestStand to identify a pattern within a larger string. This approach is useful when the regular expression matches only part of the string rather than the entire content. TestStand's FindPattern() function can be used to either:
- Verify whether a match exists and return a Pass/Fail result.
- Extract and return the matching substring.
These techniques are useful when parsing serial numbers, instrument responses, log files, or any text containing embedded data.
Example Scenario
Assume a device returns the following string:
Device SN: ABC12345
And you want to identify the serial number using the following regular expression:
ABC\d+
Expected match:
ABC12345
Since the pattern only matches a portion of the string, the FindPattern() function can be used to locate the matching substring.
