Error -8018 When Using NI ADCS Demo ECU
Updated Nov 17, 2022
  • Automotive Diagnostic Command Set Toolkit
  • NI-XNET
When I follow the steps Using NI ADCS Demo ECU CAN Ethernet for the UDS On CAN Test, I get the following error:
NI ADCS Demo ECU doesn't support all the UDS commands. Error -8018 means that the command is not supported by the demo ECU. The supported UDS commands can be found in Handle UDS Command vi located in <Program Files>\National Instruments\LabVIEW (version)\examples\Automotive Diagnostic Command Set\ADCS Demo ECUs.llb.
