When we look at the Specification document of PXIe-5830/PXIe-5831, we will find the following introduction about LO2:
From the above content, we can see that LO2 only supports the frequency band 3.55GHz~7.1GHz, but our PXIe-5830 needs to support 5GHz~12GHz. We all know that PXIe-5830/31 is a zero-IF architecture, which requires LO Resource to provide 5GHz~12GHz signal to be mixed to generate 0Hz IF signal. So we have the question, how does LO2 work?
