High-speed Mode of C Series Modules in VeriStand
Updated Oct 28, 2022
  • NI-9207
  • NI-9208
  • NI-9209
  • NI-9212
  • NI-9213
  • NI-9214
  • NI-9216
  • NI-9217
  • NI-9219
  • NI-9224
  • NI-9226
  • NI-9228
  • NI-9775
  • VeriStand
Other
  1. I would like to enable the High-speed mode of NI-9216 in VeriStand. Is it possible?
  2. I have set the Conversion rate of Device Settings in VeriStand system definition file to Maximum, but the speed of NI-9216 is still about the same with High-resolution mode speed stated in the specification. How to change the mode to High-speed mode?
For C Series module (which has "High-resolution mode" and "High-speed mode"), although it can switch between the High-resolution mode and High-speed mode in LabVIEW, there is no option to select the High-speed mode in VeriStand.
The mode switching feature is not supported in VeriStand currently. It can only use its default mode of High-resolution mode in VeriStand.
