If you are getting this message, it means that you have an invalid or expired certificate. In order to fix this issue, please use one of the different approaches mentioned in this article to generate a valid certificate signing request (CSR).
After this, please restart the NI SystemLink Services using the NI SystemLink Server Configuration tool to reflect the changes. Here is a reference:
After following these steps, users should be able to generate the reports with no issues.
