When matching a Regular Expression pattern, consider the following points to ensure that the correct result is obtained:
The CheckStrLimit and MatchPattern functions are not general purpose Regular Expression functions. These are designed to match an entire string and the pattern must accommodate for the whole string in order to return a "Passed" or "True" status. This also applies to the String Value Test Step because it uses the CheckStrLimit function when configured to compare Regular Expressions.
