Can I Display the 24-Bit Data in LabVIEW?
Updated Dec 4, 2023
I have 3 8-bit data, I want to combine them and display them in LabVIEW. Can I display the 24-bit data in LabVIEW?
You can display 24-bit data using an indicator with 32-bit representation. You can append another 8-bit with zero. After that use Join Numbers function to combine the data and display it as shown below:
snippet code
