Generate Certificate Signing Request (CSR) From SystemLink Server
Updated Oct 26, 2022
  • SystemLink Server
I am using SystemLink Server and do not know how to generate Certificate Signing Request (CSR), do you know how to get the CSR from the SystemLink Server?
You can open NI Web Server Configuration, from the HTTPS tab you can select Use a certificate from a certification authority option.
  • If your IT administrator is able to give you an already signed certification, then choose the Install an already signed certificate option.
  • If your IT administrator needs SystemLink to create a certificate signing request, then choose the Create a certificate signing request option and then choose the Install an already signed certificate option to install the certificate that IT creates.
Here is the picture for your reference:
