Change the Axis Name of Active X 3D Curve Graph
Updated Oct 26, 2022
I am using Active X 3D Curve Graph in an example program "3D Curve Graph (ActiveX).vi". How can I change the axis name?
You need to create references for each axis and update caption of the labels by following method.
