1. Supported distributions for LabVIEW on Linux for the current version are listed below:
- openSUSE Leap 15.2
- openSUSE Leap 15.1
- Red Hat Enterprise Linux 8
- Red Hat Enterprise Linux 7
- CentOS 8
- CentOS 7
- Ubuntu 18
- Ubuntu 20
LabVIEW may also work with other Linux distributions but NI does not guarantee the full functionality.
2. The development computer does not need to match the Linux distribution of the target computer.
You can run an application compiled for one Linux distribution on any other target, as long as it has the required libraries available. To build packages you should also consider classic Linux package builders like RPM or DPKG for the deployment of that application.
3. You can refer to the product documentation or readme of the Add-On, driver, or toolkit that you are particularly interested in to check the Linux OS compatibility.
