The SET-1240 expects a DC voltage between -10 V and +10 V. The ratio of the control signal voltage divided by 10 will be the gain that is applied to the excitation signal. Positive control voltages will result in an output signal that is in phase with the excitation signal, and negative control voltages will result in an output signal that is 180° out of phase with the excitation signal.
Here is a chart with some examples of control signal inputs and the corresponding outputs:
| Control Signal | Gain | Output Signal |
| 10 V | 1.0 | 100% amplitude of excitation |
| 5 V | 0.5 | 50% amplitude of excitation |
| 0 V | 0 | 0% amplitude of excitation |
| -5 V | -0.5 | 50% amplitude of excitation, 180° out of phase |
| -10 V | -1.0 | 100% amplitude of excitation, 180° out of phase |
