“Cannot Find Icon File” Error Message in LabWindows/CVI When Running Project
Updated Oct 26, 2022
  • LabWindows/CVI
The message "Cannot find icon file" occurs when I try to compile my project.
This error message specified an icon file for your project (executable) but it is no longer at the location you previously specified.
To remove the icon file or change the path to it, go to Build >> Target Settings and make sure the entry "Application Icon File" is empty.
If you want to set an icon file, then browse a valid path and rebuild your project.
