PXI or PXIe LinuxRT Controller CANOpen Support in LabVIEW 2020
Updated Jan 13, 2025
  • PXI-8531
  • NI-9881
  • cRIO-9045
  • LabVIEW 2020
  • NI-Industrial Communications for CANopen
I am using a PXI or PXIe controller with NI LinuxRT and a PXI-8531 CANOpen Interface Module. I am using LabVIEW 2020 and am unable to install the NI-Industrial Communications for CANOpen driver on my PXI system through NI MAX.
How can I use this module?
NI-Industrial Communications for CANOpen 21.5 adds support for PXI and PXIe controllers with NI Linux Real-Time installed for LabVIEW 2021 (32-bit).
NI-Industrial Communications for CANOpen 2022 Q4 extends support to this for LabVIEW 2020.
If you wish to use LabVIEW 2020 with a LinuxRT PXI Controller using a PXI-8531, install CANOpen 2022 Q4.
