Archived:Using an Up/Down Encoder With an NI S Series DAQ Card
Updated Mar 6, 2025
  • Counter/Timer Device
  • PXI-6123
  • PXI-6133
This KB will show you how you can use an NI S Series DAQ card, such as a PXI-6123 or PXI-6133, with an Up/Down or Bidirectional encoder. This KB will use LabVIEW as the programming environment and requires the NI-DAQmx driver .
  1. Refer to Appendix A of NI 6110/6111/6115/6120/6122/6123/6132/6133/6143 Feature Guide to find the pinout for your particular NI S Series DAQ card
  2. Connect Channel A of your encoder to one of the counter's Source terminal
  3. Connect Channel B of your encoder to the corresponding counter's Up/Down terminal (P0.6 for counter 0 and P0.7 for counter 1)
  4. Use a NI-DAQmx Count Edges task and set the count direction to Externally Controlled. This uses the state of a digital line (P0.6 or P0.7) to control the count direction.
  1. From here, you can use the DAQmx Read.vi to see the value/count.
NI-DAQmx installs examples that show how to perform Edge Counting with encoders.
These can be found here: C:\Program Files (x86)\National Instruments\LabVIEW 2021\examples\DAQmx\Counter Input
Note, this path is for LabVIEW 2021 32-bit. Update the version of LabVIEW to reflect the version of LabVIEW you are using. Also, if you are using LabVIEW 64-bit, change '/Program Files (x86)/ to '/Program Files/'.
These LabVIEW examples can be edited as described above to be externally controlled.
