The PXI(e)-272x is a test module that replicates the behavior of resistance-based inputs and outputs such as potentiometers, resistance temperature detectors (RTDs), voltage dividers, and bridge elements. PXI(e)-272x Programmable Resistor Module can be configurated and operated with NI-272x Reference VIs. This article explains how you can use this module in NI VeriStand.
