This article provides some general information about the RFmx Phase Noise measurement which runs inside the RFmx SpecAn personality and includes step-by-step instructions on how to take a Phase Noise measurement including the tuning of the settings.
Requirements:
The oscillators that are present in any RF communication system have several impairments, where Phase Noise is part of that list. The RFmx Phase Noise software application extends the capability of NI RF instrumentation for phase noise analysis and helps to measure log plots and spots, and integrated them. You also can perform and debug measurements with interactive soft front panels and this can be combined with the RFmx Waveform Creator to create a playback open, unlocked waveforms and speed up automated testing with the API.
NI-RFmx contains several supported personalities in InstrumentStudio for use with RF Signal Analyzer panels, and below you will find the list with a link to the licensing information for each one:
A more in-depth explanation of Phase Noise can be found in the following online help topic: Phase Noise
Note: The Phase Noise measurement requires license activation. If you install RFmx SpecAn but do not activate the Phase Noise measurement license, you will have 30 days from the first time you use the measurement to evaluate it. Subscription license information can be found in the following link: RFmx Phase Noise Licensing information
