RFmx provides signal generation and analysis for general test applications, including connectivity, cellular, and aerospace/defense test applications. When installing the driver, can choose from the software options listed below. All listed software requires a license except RFmx Waveform Creator, RFmx VNA and RFmx SpecAn.
- RFmx SpecAn.
- RFmx WLAN.
- RFmx for Bluetooth® Test.
- RFmx NR.
- RFmx LTE.
- RFmx WCDMA.
- RFmx TD-SCDMA.
- RFmx EV-DO.
- RFmx CDMA2k.
- RFmx GSM.
- RFmx Pulse.
- RFmx VNA
- RFmx Analysis Only.
- RFmx Waveform Creator ¹.
- RFmx Demod².
- RFmx Noise Figure³.
- RFmx Phase Noise³.
- RFmx Power Amplifier³.
Notes:
- ¹: Without any separate licenses, the RFmx Waveform Creator will only allow the creation of tone signals and have the ability to upload custom user signal data. In order to get access to the RF Cellular and Connectivity Standards and Analog/Digital Modulation which include more advanced features (WLAN, Bluetooth, LTE, AM/FM, etc.), you will need to purchase its respective license.
- ²: Since RFmx 20.7, RFmx Demod is available as RFmx Digital Modulation and RFmx Analog Modulation and requires a separate license for analog and digital modulation use cases.
- ³: RFmx Noise Figure and RFmx Phase Noise require licenses despite they exist under RFmx SpecAn. Similarly, since RFmx 20.7, RFmx Power Amplifier (for DPD, AMPM, Programmatic CFR, PxdB Compression measurements) requires a separate license too.
