我正在使用VeriStand的Set Multiple Channel Vales Step功能,但是我从另一个参数(Paramete)/局部变量(Local Variable)设置的值和通道,则会收到以下错误。如果我从系统定义文件中选择需要使用的别名/信号(alias),它将可以正常工作。
Details:
Error executing substep 'Set Multiple Channel Values Blocking'.
Set Channels.lvlibp:Set multiple channels.vi.ProxyCaller >> Set Channels.lvlibp:Set multiple channels.vi >> Set Channels.lvlibp:NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Set Multiple Channel Values.vi
NI VeriStand: Alias "" is not linked to any channel.
NI VeriStand: The system definition contains aliases that are not linked to any channel. Click on the Error/Warning icon on System
Error code: -307617; User-defined error code.
