I'm using the VeriStand Step Set Multiple Channel Vales, but if I configure the values and channels to be set from another Parameter/local variable, I will get the below error. It will work fine If I choose the aliases/signals that I need to use from the system definition file.
Details:
Error executing substep 'Set Multiple Channel Values Blocking'.
Set Channels.lvlibp:Set multiple channels.vi.ProxyCaller >> Set Channels.lvlibp:Set multiple channels.vi >> Set Channels.lvlibp:NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Set Multiple Channel Values.vi
NI VeriStand: Alias "" is not linked to any channel.
NI VeriStand: The system definition contains aliases that are not linked to any channel. Click on the Error/Warning icon on System
Error code: -307617; User-defined error code.
