This error usually occurs when the power supply encounters a high frequency, common mode power or voltage spike.
If the device becomes stuck in a protective mode, functionality can be restored by resetting the device.
To prevent the error from occurring, several measures can be taken. These are listed below.
Check Grounding and Connections
Often times, a sudden voltage spike will cause the device to enter a protective state. This may be due to:
- Voltage peaks between the PXI chassis ground and the isolated source output of the device.
- Improper grounding of any devices that are a part of the PXI system.
An oscilloscope can be used to monitor the signals between the PXI(e) device and the chassis ground. This will highlight any common mode transient that may be present.
Closing the Output Relay of the Device
PXI(e) Power Supply cards have an output relay that disconnects when the PXI system is powered on. This relay is controlled by the
Output Connected Property.
If the relay is open at the beginning of the operation, this error can occur.
By default, this property is set to True, which means that the relay is closed whenever
niDCPower Commit or
niDCPower Initiate are called. To open the relay:
To ensure that the relay is in a closed state when beginning any tests, the niDCPower Commit VI can be used with a Wait function at the beginning of the device's configuration.
Removing Common Mode Transient
A common mode choke can be used to try and remove the common mode transient. When doing this, both leads from the device can run through the same choke. However, the wires should wrap around the choke several times. A diagram of how this can be seen in this article.
Alternatively, a low pass filter can be implemented to help reduce the common mode transient.
