LabVIEW's Error Out cluster shows me an
Error xBFF62024 when I am trying to run NI-CAN Write by using Call Library Function. The PCI-CAN is working properly on other tester and passed NI-MAX self test. But when it is used on our newly setup Windows 7 computer, this issue occurred. Once this issue occurred, I have to restart the computer in order to have the PCI-CAN works again.
Error Code: xBFF62024
Error Source:
NI-CAN Write
CAN Network Interface Object (ncWriteNet.vi)
