Export .Ldf File From NI-XNET Database Editor
Updated May 12, 2025
  • NI-XNET
Other
App: NI-XNET Database Editor
How to export .ldf file from NI-XNET Database Editor?
As the help file said, you can export the LIN cluster as .ldf file. If you click File->Save as, you will save the file in FIBEX Database File(*.xml). If you create a new LIN cluster, please right click on the cluster, select Export to LDF, then you can save your cluster in .ldf file.
