Simultaneous Voltage and Current Output in PXIe-4322
Updated Apr 28, 2020
  • PXIe-4322
Can the PXIe-4322 card generate both a current output signal and a voltage output signal at the same time?
The PXIe-4322 card is able to generate both a voltage output signal and a current output signal with the following considerations:
  • The signals must be generated in separate channels.
  • You can't control the voltage of the current signal nor the current of the voltage signal.
  • The generation can be done on separate NI-DAQmx tasks or on the same one.
