Can I Use CR2032 Instead of BR2032 Battery to Replace PXIe-8880 CMOS Battery?
Updated Jan 14, 2026
  • PXIe-8880
Can I use CR2032 instead of BR2032? In my country it is hard to purchase BR type battery.
Important: NI is not liable for damage incurred while changing a CMOS battery.  The recommended procedure is to send your controller in to Return Material Authorization (RMA) to have the battery replaced; however, the 3 Volt battery can be replaced by an end user if desired.
It is not recommended to use any CR2032 battery instead of BR2032. As of September 2021, PXIe-8880 use Murata CR2032W 3V Lithium coin cell.
