If the data is not loaded correctly to the DIAdem, make sure that the correct Dataplugin is being used.
When opening a data file in DIAdem, DIAdem only uses the filename extension to decide which DataPlugin to use to load the file. If several DataPlugins are assigned to one filename extension, for example *.
DAT, you can change the DataPlugin priorities in the DataFinder configuration.
To determine the order in which DIAdem uses the DataPlugins, select
Settings»My DataFinder»Configure in DIAdem NAVIGATOR. Click the
File extension tab and specify the priority list.
You can raise or lower specific DataPlugIn. The top priority one would be chosen first whenever the corresponding extension file loaded in DIAdem.
