The number of signals is limited to a maximum of 5000. Follow the steps below to configure it:
1. In the menu bar, select
Settings >
DIAdem Settings.
2. In the DIAdem Settings window, under
Panel select
DAC/VISUAL >
Mea. Kernel... button. 3. In Measurement Kernel Settings window, select
VISUAL then modify the
Signals value. Depending on the type of DAC device reported in the error, you can configure the signals value for different DAC devices.
