String values in LabVIEW are compared according to the values of the
ASCII character codes .
Therefore, they compare those values from left to right, and not based on the numeric values.
For instance, if you compare a large value with extra leading zeroes as a string, LabVIEW will consider it smaller than a value that has no leading zeroes.
(i.e. 1000 > 01001)
If you would like to compare the strings according to their numeric values, you must
convert the string into a numeric value first.
