Archived:Disabling Grid Alignment of Front Panel Objects in LabVIEW NXG
Updated Oct 20, 2022
  • LabVIEW NXG
  • I want to resize the front panel objects in LabVIEW NXG without having them aligned to the grid in the background. How can I do that?
  • How can I resize the front panel objects in LabVIEW NXG without being restricted by the grid size?
Perform the following steps to disable grid alignment of front panel objects in LabVIEW NXG:
  1. Select File >> Preferences from the toolbar at the top.
  2. Select the VI tab.
  3. Uncheck the Snap to grid option under the Panel editing defaults section.
