Display ASCII to Hexadecimal Correctly in LabVIEW
Updated Sep 21, 2023
I want to do conversion from ASCII to hexadecimal using below programming but when I insert #,
the result that I get is 23000000. How to display the result as 23?
The result is displayed as 23000000 is because the numeric constant representation at the Type Cast Function is a 32-bit integer.
To display the result as 23, right-click the numeric constant of the Type Cast Function, select Representation and choose 8-bit integer.
