Changing NI Linux RT OS Network Settings Using Command Prompt
Updated Sep 11, 2026
  • PXI Controller
  • CompactRIO Controller
  • How can I change the network settings on the NI Linux RT OS from Static to DHCP using the command prompt?
  • How can I use the command prompt to modify the NI Linux RT OS network settings for Subnet mask, Gateway, and DNS?
You can use the command below to change the network settings from Static to DHCP as shown below.
nirtcfg --set section=ETH1,token=dhcpenabled,value=1
On the other hand, if you need to configure your network settings with a Static IP Address, you should set both the dhcpenabled and linklocalenabled tokens to zero using the following commands:
nirtcfg --set section=ETH1,token=dhcpenabled,value=0
nirtcfg --set section=ETH1,token=linklocalenabled,value=0
You can use the command below to change the network settings for Subnet mask, Gateway, DNS and Link Speed:
  • IPv4 Address:  nirtcfg --set section=ETH1,token=IP_Address,value=10.161.81.1
  • Subnet Mask: nirtcfg --set section=ETH1,token=Subnet_Mask,value=255.255.255.0
  • Gateway: nirtcfg --set section=ETH1,token=Gateway,value=10.161.81.1
  • DNS: nirtcfg --set section=ETH1,token=DNS_Address,value=10.161.81.1
  • Link Speed: nirtcfg --set section=ETH1,token=MediaMode,value=100Full (available value is Auto, 100Full, 100Half, 1000Full)
Note: It is compulsory to restart the network after modifying to make sure the network settings are properly configured. You can restart it by using the following command: /etc/init.d/networking restart
