NI-XNET Application Crashing if “Shared Clone Reentrant” Mode Is Enabled in LabVIEW
Updated Apr 29, 2025
  • NI-9860
  • cDAQ-9189
A LabVIEW application using NI-XNET hardware is crashing after a random period of execution, once the crash takes place, the hardware shows up in NI-MAX as disconnected or not available. A reboot of the chassis is required in order to re-establish communication with the affected hardware.
If the XNET Read VI is called in a VI or SubVI with execution mode set to Shared clone reentrant execution the application might crash.
The current workaround is to change the execution mode of any VI or SubVI calling the XNET Read VI to Preallocated clone reentrant execution or Non-reentrant execution
Contact Technical Support if the application crashes after implementing these changes.
